91 Q45 - Steering "Whine"
fhatfield
Car: 1991 Infiniti Q45
Hi Guys,
I'll preface this with the fact that I am not a car guy at all, but I'm trying to learn more about this stuff. So, any advice or guidance you can provide is MUCH appreciated. :)
I have an older '91 Q45 that I inherited from my grand father. Overall, it seems to be running pretty well, except for a "whining" noise that seems to be related to the power steering. I suspect that it may be leaking steering fluid, as at one point the power steering was really awful, and by adding some more fluid it improved drastically. Any advice on how to go about troubleshooting it to figure out the exact cause of the problem?
Also, a side question. The manual recommends a higher grade fuel than the typical 87 octane. Is this a valid recommendation? Does it really require a higher octane fuel?
Thank you so much for any information you may be able to provide!
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Did you put power steering fluid in or transmission fluid?Check all hoses for leaks?Look under car at axles for leaks from busted boots?Yes you need to put 91 in,although I have put in 87 to 93 and have not noticed a difference.Just pay the extra cents.As other members chime in,they will tell you if you do not have money to maintain car it's not for you.Think it was quoted at $3000.00 a year to keep one in tip top shape.
fhatfield
black g50 wrote:Did you put power steering fluid in or transmission fluid?
Power steering fluid
black g50 wrote:Check all hoses for leaks?Look under car at axles for leaks from busted boots?
I'll check this out. Do you mean a visual inspection? Or is there a better way to test for leaks?
black g50 wrote:Yes you need to put 91 in,although I have put in 87 to 93 and have not noticed a difference.Just pay the extra cents.As other members chime in,they will tell you if you do not have money to maintain car it's not for you.Think it was quoted at $3000.00 a year to keep one in tip top shape.
Gotcha, thanks for the advice.
Q451990
Leaks on the high pressure side will show up when you have the steering wheel turned to a stop... I had a leak on my old Q that I never noticed, becuase it was spraying out of the bottom of a hose - but only under a load.
Heath
black g50
I believe it takes ATF not power steering fluid.
Q451990
black g50 wrote:I believe it takes ATF not power steering fluid.
That's correct.
fhatfield
ATF? Forgive me, as I'm mentioned, I'm a newbie.
black g50
Transmission fluid.
