Well, that would rule out the MAF. It could be the injector sticking open.navyman_98_99 wrote:I just checked the fuel pressure regulator and it is good. it seams like it loading up on one cylinder. not all of them.Thanks Mike
Sounds like it could be a bad lower injector o-ring, if they ohm out nice. An infrared temperature sensor aimed at the exhaust tubes will tell which one is cool.....at least you'll know which one.navyman_98_99 wrote:nope, no check engine light. must be one of my injectors. I will take the plugs out after running it a little bit and see which one is really wet, I bought new plugs and installed them so it should tell me. because all the injectors ohm good.Thanks Mike
Ooooops! Hope the ECM is OK!navyman_98_99 wrote:not just one of my plugs are foulded, they all are. It has to be my maf, I accidentlay wired it wrong when putting on new plug. I switched the battery voltage wire with the sensor wire. I think maybe i messed it up.
