91 Q45 power steering
1bluestraveler
Car: hunting fishing blues golf
the power steering is working part time, probably the pump. However I've heard that there is also an electrical module with the PS, am I wrong or could this be part of the problem?
Q451990
Does the speedometer drop out at the same time as your p/s failure?
There are also test methods to check the p/s solenoid in the factory service manual... do you have one?
Heath
1bluestraveler
No the speedo is fine, and I do have a service manual, Mike
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
How often have you mechanically exchanged the fluid?
When and how many miles ago did yo replace your belts and pulley tensioner bearings?
It pays to read the stickies at the top of each Forum before posting.
Do complete your profile please.
1bluestraveler
A rebuilt engine was put in 2 1/2 years ago, everything was changed at that time. The stickies on the top of the page didn't show anything reguarding a electrical module. I was just wondering if it was valid information.
goody90q45
Car: 1992 Infiniti Q45 (sold)
There is a power steering control unit under the dash but they're not known to go bad. Look in the EL section of the FSM- Location of Electrical Units, Passenger Compartment.
It's more likely a bad PS pump or PS pulley, air in the line, an idler pulley bearing siezing, or the transmission's speed sensor (except the speedo's OK).
Any odd noises? Recent maintenance? Losing fluid?
Q45tech
T3 has probably replaced 30 power steering pressure control units in 10 years. Always a hot item from a junker.
