Q45tech wrote:The reason Nissan spec 10-14 ohms is to avoid warranty, and to allow for variances in ohmmeters their batterries and the temperature of the injector coil.
Once temperature stabilized all should be within +- a few tenths of an ohm because all the coils have exactly the same wire and number of turns.
I measured 6 new injectors they all read the same with +- 0.1 ohms.
Obviously meters have different accuracy so the exact ohm number is not important JUST THAT ALL INJECTORS READ THE SAME when tested.
I have long wondered why so many Infiniti injectors go bad. Generally speaking,since there are no moving parts in electronic devices, barring manufacturing defects and/or physical abuse (shock and extreme thermal environment), electronics have a good reliability record. Electric motors also have good reliability record, and generally, only excessive current flow or physical damage harms windings. I would think that the designers of Infiniti fuel injectors would have taken into account the temperature fluctuations present in an automotive application, and the repeated shock/vibrations of a device close to the combustion chamber. Strangely enough, it is usually not the moving parts in Infiniti fuel injectors that fail, but rather the windings in the operating coil.
I can understand how electrical connections can become loose or corroded, and how complicated electronics circuit boards can develop minute cracks, but even these things are not so frequent that they ALWAYS die within typical time periods as do Infiniti fuel injector windings.
It seems that these injectors only last for a given length of time before failing. Interestingly enough, I'm familiar with other manufacturers whose fuel injectors almost never fail.
So what is it that causes Infiniti injectors to "not ohm out? What causes the windings to short or open, and why after so many years of this phenomenom has Infiniti not addressed and fixed it? Finally, is there anything owners can do to prolong the life of injectors? Their failure involves great expense in parts cost and labor, and is one of the most frequent and costly parts of maintenance that is a part of Infiniti ownership. I see no reason why injectors cannot be made to last as long as pistons/rings, bearings, and valves, all of which take a terrible beating in their normal function , yet unlike fuel injectors, last for hundreds of thousands of miles.
