Post by CastorTroy777 » https://forums.nicoclub.com/castortroy777-u28251.html Fri May 20, 2005 7:21 am
Post by maxnix » https://forums.nicoclub.com/maxnix-u127.html Fri May 20, 2005 7:15 pm
Nissan expressly warns against using cleaned plugs in the FSM, but Heath's method should be fine. No abrasives, stiff metal brushes, nor caustic or acidic cleaners should be used.Q451990 wrote: After the repair, just clean that one plug... I've used an old tootbrush and gasoline. After it's sparking again it'll burn off the rest of the residue.
Heath
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
