anlasak wrote:
I completely agree with R/R the pump.
Still doesn't answer my question though.
Are the waterpumps on Q45's designed to leak from the bolts as well as the "pee" hole?
I've never seen it before, but I'd really like to know how they did it.(If they did)
I had the same problem with my 92. It appears as if the leak comes from one of the bolts, but if you were able to look close enough, most likely you'll find that the leak is from the "nose" of the pump, due to failing bearing/seal and trickles down to the lower bolt/s.
This was my experience when my car had 120000.
As a side note, I agree with replacing the pump and look for signs of anything abnormal.
CGB
