91 Q45 fuel injector orings?
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
I need replacement o-rings for my fuel injectors, wanted to know if I can use a round o-ring for the bottom of the injector instead of a flat one? The original is a flat o-ring, I'm looking for a substitute, has anyone used a round o-ring to replace the lower o-ring on a fuel injector? Also, can I mix the combination of the injectors, my original ones have the yellow dots and my replacements have the green dot?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I hate to be that guy but when it comes to the difference between a hydro locked engine because of a improperly seated o-ring or mismatched one I would buy it from the dealer. But the O-ring set I got from the dealer are rounded.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Mikey_ZX wrote:I need replacement o-rings for my fuel injectors, wanted to know if I can use a round o-ring for the bottom of the injector instead of a flat one?........
They should be round but yours have been sitting in the fuel rail cup compressed for 20 years. Hence the flat side. The pic shows the OEM o-rings. Are you replacing all 8 o-rings or just a couple for injector replacement?
Don't worry about the color of the dot on the FI. NICO lore has is that they were sorted by spray pattern but mixing dot colors at this point in the engine's life will have no perceptible effect on performance.
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Thanks Mr. G, I'm replacing the o-rings for all injectors not within' ohm spec, my fifth cylinder wasn't firing and that injector wouldn't even ohm out, one injector was in the 30's and the third injector ohmed out about 10 (not sure if its good or bad, read that fl should ohm 10-14, just figured it would get low within' time). I'm replacing my bad injectors with a few used ones that I was able to acquire, that's the reason why I have mismatched ones. Thanks Infinitiguy19 and Mr. G for your help in answering my questions!
DeatschWerks
I'm pretty sure we have the specs for the phase I side feed injectors.
Our oring kits for 8-cylinders are $28 + shipping.
Q451990
Mikey_ZX wrote:...and the third injector ohmed out about 10 (not sure if its good or bad, read that fl should ohm 10-14, just figured it would get low within' time
Typical failure mode is for them to rise until opening, rather than dropping. Either way, if you trust your ohm meter, you might as well replace it while you're in there. I would hold on to that one as a spare though.
Heath
ericthered
Car: Past: 06 M35x, 94 Q45t, 92 Q45, 91 Q45 w/HICAS
old nico name: JedCoop
First, always use vaseline (insented) to lubricate o-rings.... a poorly seated o-ring will cause you no end of grief.
When ohming the injectors, ohme them when HOT. To get them hot, drive your car to thoroughly warm it. When you get home, stop the car and wait ten minutes. The injectors will get hotter because the fuel flow is not cooling them any more.
Then pop the hood and ohm them quickly.
Even if in spec, if an injector changes a couple or more ohms between hot and cold readings, change it now, or remove the plenum a second time when it dies.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
They are available from
Bill Johnson / Mr.Injector
6280 N Government Way #4
Dalton Gardens, Idaho 83815
208-762-3450
http://www.mrinjector.us/
I recommend Bill also for injector cleaning as he actually pressure tests the rail assemblies after assembly. Some others do not.
DeatschWerks
We've been a long time supporter of NicoClub, and have always had a NicoClub Forum Special Service: post6204989.html#p6204989
Infinitiguy19
maxnix wrote:They are available from
208-762-3450
Do you have any experience with these guys?
qship96
Car: 1996 Infiniti Q45
Paul, are you stirring the pot?
Infinitiguy19
"Stirring the pot"?
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
Infinitiguy19 wrote:"Stirring the pot"?
As in trying to antagonize.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
208-762-3450
Yes, and with some others also. Why I recommend Bill.
