'91 Q45 Front Corner Light Removal
timatt
I am trying to change a bulb for my parking lights. Can someone enlighten me how to remove the front corner light assembly? This is the assembly that holds the parking light and turn signal and is located immediately outboard of the headlamp assembly. From the top under the hood, I removed the black plastic cover then removed the phillips head screw holding the assembly. The assembly is still held in somehow. I don't want to pull too hard and break something. Is there another fastener? Where would that be and how is it accessd???Thanks
Timatt
timatt
Once again!
Sorry for the double post. I checked the board earlier today and my provious post on this subject did not appear. After reposting, bost posts appear.
timatt
fxjackso
See the maintenance section of your owner's manual, or the FSM. There is a push connector (male) on the back of the signal unit. It goes straight into a female socket on the mounting behind it. A surprising amount of pressure is needed to remove, or install,it.
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
Wiggling from left to right while pulling out will be the easiest way once you remove the screw.
Ron Marra
one of my parking lights has moisture in it, is it toast?The light still works.If I need a new unit, where can I go to get a reasonable price
Ron
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ron... Take it out and dry it out really good, maybe theres a hole you could patch up with some clear tape or soemthing (i have clear tape on one of ym foglights, youd never know it was there)...
You could get a new one from Joe, theyre probably not bad.....
Tim... There is this ball socket deal and you basically gotta pull it out, and it pops out after the screw is removed......
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Look for fissures in the housing and fill them with epoxy once you have cleaned and dried the reflectors very carefully.
