SFBayQ45 »
https://forums.nicoclub.com/sfbayq45-u9053.html
Tue Jul 29, 2003 7:10 am
I recently made a huge investment to have my engine and transmission replaced with one of those used Japanese engines that's guaranteed to be less than 60K miles. Despite the lost of time it's been sitting in the car shop, the vehicle still does not run well. The engine seems to respond with moderate vibrations upon the slightest push on the gas pedal. I noticed that this is not necessarily the case when the engine isn't warmed up. For example, the car doesn't display the now-normal vibrations when I drive it for the first few minutes.
The garage mechanic could not determine the problem. Subsequently, he brought it to another shop with more modern/advance equipment to diagnose the problem. That shop couldn't determine the culprit either. They both confirmed that the engine is good with no error codes. They also confirmed that the injectors and compression test are good as well. As a last resort, the mechanic brought it to the Infiniti dealership to have it look at however I felt that he might have massage the answer from the dealership in telling them that it might be related to the drive line. And sure enough, the dealership came back and confirmed with the mechanic that it MIGHT be a drive shaft problem. The dealership confirmed the vibration upon acceleration, and that the vibration is also noticeable at higher RPM in neutral. The dealership printout also indicated a "misfire", which the mechanic failed to mention until I brought it to his attention. When I made him aware of it, he simply explained that the dealership needs to fix the drive shaft before the misfire could be determined correctly. Because I know very little about cars, I don't know what the mechanic is telling me is factual. I find his explanation, at best, unsettling and suspicious. One last thing I forgot to mention. The mechanic said he didn't tell the dealership that he swapped engines because he wants the dealership mechanic to look into the full diagnostis without any preconceived notions. Does that make sense?
Lastly, I always suspected that the reason my cabin is overflowing with a strong smell of gasoline is because of bad injectors from my previous engine (at least that’s what one mechanic told me), but the same problem persist despite the new engine. Do you have any idea why this is a lingering problem? I appreciate any feedback.
