1bluestraveler »
https://forums.nicoclub.com/1bluestraveler-u11005.html
Sun Apr 24, 2005 11:38 am
That's what I understand Jedcoop, the traction control cars are different. At a local yard I found 2-93s and 1-94 Q's being parted out, none of them were traction control tho. I found several others around Denver, already out of the car for $100-150. You probably have a pretty good quantity in your area as well if (Q45denver's) doesn't work for you. My parts engine was rebuilt by someone who had high confidence/low competence, it's not been torn down but brass was found in the pan so it's probably a spun bearing. Approx. 150k miles, different crank, also changed 1 head. The transmission is 150k, running great when it was pulled.
