DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Mar 22, 2005 10:55 am
It means to use brake fluid as a cleaner to wipe down the calipers. If you're doing a total rebuild/repaint this is not good. You'll need to clean/degrease completely, and prime them quickly to prevent rusting. No paint allowed in the piston bores of course. As soon as the paint is dry install seals and pistons, then either install them or coat the inner surfaces with brake fluid to prevent rusting.
