forecast »
https://forums.nicoclub.com/forecast-u7026.html
Tue Jun 03, 2003 10:27 am
first off do you have the bible sized service manual? It will walk you through the steps of testing the output of this device with a voltmeter at the consult connector before you need to rip into anything.
Roughly speaking it is directly forward of your right knee, about 4 inches inside the dash.
You'll need to pull several panels to get access to it.
1. Steering wheel covers2. Lower driver's side cover (above the pedals)3. Central Console cover
Looking up and in with your head under the steering wheel, you'll see a "pack of cards" sized aluminum box. An inch wide metal strap runs across it at a diagonal and bolts with two screws to the cruise control computer. It has a single wire harness
The identical model is used in at least 90-94, and possibly beyond that.
