SLEEPER 86 »
https://forums.nicoclub.com/sleeper-86-u18602.html
Mon Apr 21, 2008 4:30 pm
never seen this one before,4WD, engine family; MNS3.0T5FBF1 engine runs great when cold, but as it starts to reach operating temperature, it starts to sputter sporadically. this gets worse until the engine starts backfiring out the intake and exhaust, bucking, and finally dies. i checked the ecu codes and got a 21 (interruption in ignition signal). replaced a completely wasted dizzy cap and rotor (cap was missing the contact pin that touches the rotor!), that seemed to clear the code. i replaced the fuel filter because the random sputering made it seem like water in the gas. still did it. broke out the timing light and it looks like the marks are around 3:00 instead of 12:00 where they should be! can a timing belt jump time like that? the marks look very stable after about 5 minutes of run time but i heard it starting to sputter and pop again so i shut it down. could this have something to do with the crank sensor in the dizzy? once the engine cools off, it runs great again any ideas would be greatly appreciated! thank's in advance Eric B
