Graham »
https://forums.nicoclub.com/graham-u230161.html
Mon Jan 13, 2014 12:59 pm
Hi all. I have a 91' Nissan pickup 2wd. The trouble I am having is that the key is stuck in the ignition. It will turn and start just fine, but when I stop and turn the truck off the key will not go into the lock position and release. I press the release button but it is stuck and will not release. I opened up the column and clicked the emergency release, press the button, and it lets the button go in and the key goes into lock then releases. I put the key back in the ignition and start the truck, turn it off, and again it will not go into lock and release the key unless I use the emergency switch. I do not want to drive around with out the steering covers on and use the emergency release button to get the key out every time. Can someone tell me what this is and how to fix it?
