91 Nissan Hardbody Pickup Question
metalsyth
Car: 2001 Nissan Altima
When accelerating inbetween 1500 rpm and 2000 rpm it studders and after 2000 rpm it runs good and strong and that is true before 1500 rpms. Idle is fine. Is this a bad sensor problem? If so which sensor do I need to look at? If not then any idea of what is causing it would be greatly appreciated.
If I hold the gas at about 2000 rpm it will go up to 2000 rpm and drop to 1500 rpm and back up to 2000 rpm and will keep doing this in a constant pattern until I give it more gas or let off the gas.
It is a 1991 Nissan hardbody pickup with a KA24E motor.
Modified by metalsyth at 10:10 AM 12/1/2004
metalsyth
*Bump*
s13sr20chris
not sure off the top of my head. need to verify the basics...timingfuel pressurevac leaks(spray intake manifold with carb cleaner)unplug o2 sensor to see if it changes at allcheck plugs and tell us what they look likelet me know that stuff and we will go from there
metalsyth
One quick question what will I be looking for when I spray the Intake Manifold with Carb cleaner to find a vacuum leak?
Also with the plugs you are talking about the spark plugs right?
s13sr20chris
1)any change in engine rpm2)yeah
metalsyth
Ok timing I know is good and I know the fuel pressure is also good.So I'll check the O2 sensor and the plugs this weekend.
