91 maxima water pump (Yes I know this is IOM)
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
How hard is it to change the water pump on a 91 maxima?
Someone said you MUST replace the timing chain.
Is this true?
DAEDALUS
Car: 1990 Infiniti Q45
If it's the same as the z engine (I think it is) then you have to remove the belt to get to the pump.
metaverse3
It is a tough area to work on..by the passenger fenderwell. The car is worked on from below after removing the passenger wheel and fender inner guard (plastic piece)
There are no timing chains on 91 maxima. 92-94SE with the DOHC engine has the timing chain. 89-91 GXE, SE' both had the timing belt with the sohc engine.
Waterpump is in the same area and shoud be replaced period. You will not enjoy this job..bewarned..
GreenQ45a
Yeah I just remebered my 86 300ZX...
I had to the water pump on that thing. @least it was mounted inline not transverse.
So I just removed the front of the car cowling, radiator...ect...I did have to remove the TB cover now that I think about it...I must have blacked it out...
Thanks for it response's
My friend that bought my old 91 Maxima now needs this done I told him I would help..
He was was told 500.00 to do the job.. gonna get started this Tuesday..
