MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sat May 05, 2007 1:35 pm
Generally, the cause for malfunctioning door locks is a bad lock timer unit. The timer (like too many other electronics on early 90s nissans) has poor solder joints. Usually you can fix the locks by removing the timer device and cracking it open. Then you just touch up any bad-looking solder joints and re-install it.The timer unit is under the driver side dash. You'll need to remove the lower dash covering and you'll find the timer unit to the right side of the footwell, stuck partway behind the center console stack. It's the smallish black plastic brick with rounded corners that has two wire harness connectors clipped to the bottom. It sits in front of a larger metal-encased electronic unit. You'll want to unhook the connectors and then use a screwdriver (flathead) stuck in the seam at the bottom to pry the part the connectors plugged into out of the rest of the box. The whole bottom face and internal PCB slide/fall out when you pry on it, and then you're free to fix any bad solder joints. When you're done, just slide the board back in.
There are two different things that could be responsible for the locks not getting power, though. The first is the under-dash circuit breaker. The second is the fusible link that protects the door lock timer. The fusible link is right after the battery and is a length of green wire. I'm not sure exactly where the breaker is under the dash...I've never had to use mine and I've only ever seen it in schematics.
