This is a pretty common problem. It's an issue with the lock timer, which controls power lock behavior (when you lock either front door by manual button OR power switch, the power locks are engaged for all four doors).
Jay85 wrote:So what I did to fix the problem was turn the key and start the car, close the door and if the driver side lock is unlock, push it lock manually.
The car's actually designed not to let you lock your keys in the car. So if the key is in the ignition and either front door is open, the locks will stubbornly unlock themselves.
