91 manual to 95 auto
Big Manne
Car: cars, muzic, females
my question is, how complicated would it be to build a 91 ka for turbo but i want to use my 95 auto trans. are the motors the same, could i just build the 91 ka and just drop it in my 95 auto .or is there a **** load of stuff i would need to do to make it work. i found a guy wanting to sell me his 91 ka for 250 is that even a good price i know it will need a new headgasket.
Structure240sx
u will have to put an auto pilot bushing on the 91 if it was a 5spd engine. 250 is kind of alot for an engine that needs a headgasket i think, unless it has really low miles. since you going to build it for turbo find the cheapest engine you can
tonynalli
correct me if im wrong but did you say that you wanted to convert a maunal to auto????
Big Manne
yea thats what i said i know it sounds odd and why would i want an auto. im building a turbo ka and i want boost when my auto shifts and for those fun times at the drag strip
tonynalli
you better be sure that you transmission can hold all the power. i did some modifications to my 240 with the auto transmission and i was forced to do the swap.
Structure240sx
my turbo ka started as an auto. it was holding 10psi jsut fine. all i had a was a transmission cooler, if that even did anything
tonynalli
if you need any parts like the axle and some other parts ask me cause they are lying around the house...ill sell em dirt cheap
