91 ka24de swap
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
I swapped my ka out for a 95 ka24de since mine was destroyed, everything is wired up all of the grounds as to my knowledge should be right I originally blew my 75a alternator fuse because I forgot the plastic piece on the alternator now the car turned over like 2 seconds before it blew. since the motor won't turn over I even put a new starter in all of electric stuff works since I replaced 75a but no turn over I'm pretty sure its the wiring on the alternator and starter because the starter doesn't even click but I have spark and I've cleaned all of my grounds. any ideas? or it'd be great if someone has a link or diagram of all the grounds.
destroyyourmind
I'm not 100% on the starter grounds anyone have a picture. and there is also a plug on top of my transmission by the shifter that was cut that I ghetto rigged had green wires. theres a plug behind my valve cover closest to the firewall that had some cut wires. replaced the hoses but the plug from my harness was cut, and another plug beside the oil filter on the block thats got the old plug stuck on it still. anyone know any of these plugs?
destroyyourmind
I figured out one problem the oil pressure sensor plug wasn't plugged could I have hurt my motor turning it over?
destroyyourmind
still nothng...
PROJECTiMURA
Car: 91 RMS-13
give me a call i have the fac man for the car! 305 766-9280
destroyyourmind
still tryin' to figure it out, I found my neutral safety switch plug on the transmission was ****ed so I replaced it and its still doing the same thing all grounds are good, 12.5 on my battery alternator and starter with a multi meter and it just turns on and the car won't turn over at all only my electronics come on anybody know of anythingggg?
destroyyourmind
seriously nobody knows any reason why?
