davidoliva wrote:Try a leak down test, if all else fails take it to the shop
Negative ghost rider the pattern is full.......shop?! I AM THE SHOP! hahahha i joke
Ok so.....igniton coil wires came off.....( they are modded factory clip is gone ) once that was fixed, it fired up! Still runs better in limp.....got good volts to MAF while running. I am going to confirm continuity from the ecu to the plug this weekend, but i am thinking now its the ECU or the wire being s*** somewhere in the harness. No smoke while running, just running rich. Still going to double check injectors but im sure there not leaking by. Any previous problems and or issues similar to this let me know what you found! i am pretty confident its the MAF and something to do with it....main reason is the big difference when u unplug it. Thats all for the update thanks again guys, pics and more info to come once more troubleshooting goes down.
