SixxTwo »
https://forums.nicoclub.com/sixxtwo-u42566.html
Sat Sep 23, 2006 1:53 pm
Replaced water pump and thermostat at the same timeas the old water pump had gone bad.
My belief is that either the new thermostat isnt opening, or the belt on the water pump may? not be tight enough.
I believe that the belt is fine more then the thermostat. I get heat thru the system so I'm fairly sure the water pump is working. Also, I can feel the heat from the heater getting warmer as I drive. (and warmer as it overheats)
I have boil tested the new thermostat and it does open (not sure on the exact temp tho)
plus while test driving it the temp fluxed quite a bit... I took it out for a time and it was fine... then the temp went up higher then I was really comfortable with then went back down to normal.....then it did it again, except it didnt go back down, so I made a quick run to the backyard =D
Never really had this issue before I changed these parts.thermostat is in the correct way.
Also how would coolant get onto the other side of the thermostat to open it? I poured it into the outlet (upper) side of the block but Im not sure if that is enuff or if there is air in the system
Also the hose on the thermostat intake side (bottom hose) isnt even warm at all. which further makes me think the thermostat isnt opening
I have no clutch fan, but have wired the electrical one to constant, as in on of the installs area
So any Ideas?
Belt? Belt tensioner? Bad Thermostat? fan not enuff?
Help! I gotta go back to work on monday
Sixx
Modified by SixxTwo at 5:53 PM 9/23/2006
