91 JWT ECU good for 91 model years only?
PalmerWMD
Car: 2004 350Z
i saved my jwt ecu from my wreck.It's a 91 will it work only in 91's or other model years as well?
Fred...:)
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
I've got a POC at JWT, Ben Pila. #619-442-0680 or http://www.jimwolftechnology.com I'll bet he could give you a definitive answer Fred. You got your TCU too, didn't you?
Q45tech
The differences in year of ecu [90-93] were fine tweeks in the idle, emissions, cruise, TC lock up as they tried to fix little annoyances.Obviously Hicas, TCS, and Active required their own ecu as sensors outputs were different as did California emissions.
JWT does nothing to non WOT parameters except recurve the ignition advance/retard when you suddenly open the throttle from a cruise [in the period just prior to downshift] to suppress knock because the timing recovery from a knock wastes time in acceleration.
