silvia s14.5 rb25det »
https://forums.nicoclub.com/silvia-s14-5-rb25det-u95407.html
Tue Jun 30, 2009 4:04 pm
I decided that since I'm going to school to be an automotive master tech, that I might as well re build the Ka in my 240sx.
all the turbo parts are probably not going to be for a while due to me being a full time student, and having to get a s**tty job because no shops in Raleigh are hiring part time techs ahhhhh, but the ka will have a fresh new look and be ready for boost
I started with ripping the motor completely apart and cleaning any and all things I could re use, and replacing everything that needed to be replacedI only have a few mods for this ka as of now, arp main,head and rod bolt studs, a triple layer metal head gasket, ngk spark plug wires, and a msd ignition set up. oh and my hockey puck motor mounts. the head was sent off to the machine shop for milling/ cleaning/ cam rotation check, and a vacuum check after I lapped the valves in. I also got all new shims for the valve clearances which are now all an even 4.5 thousandths.I want this first project to be a DD for school and work. after doing some research I found that the ka could handle around 350hp plus with stock rods and pistons. a good fuel system and a professional tune and of course all the rest of the turbo parts needed to boost the Ka . So I think i will have a pretty solid motor when it's all said and done. I'm not all exactly sure specifically what turbo parts I'm going to use but i have set my goal at 350hp.I have a pretty good idea about the turbo set up I'm going to use.here it goes.
Gerret t3/t4 hybrid ball bearing turbo. i may just go ahead and get a Garret gT30 ball bearing turbo since i will be having some 720cc injectorssteel braided turbo oil feed lines/w oil filter adapterxcessive ka24de intake manifoldwalbro 255 fuel pump Megan racing fuel pressure regulator/w gaugez32 fuel filtertop feed fuel rail w/ steel braided fuel lines 720cc top feed injectors top mount turbo exhaust manifoldz32 maf sensorhks ssqv blow off valveebay intercooler and pipingdown pipe 3" buddy club turbo exhaust/w dual tipkoyorad radiator electric fan( already have)aem stand alone ECUaem true boost gauge type boost controller aem wideband
Heres what I have put out so far with the pics. The whole motor is put together and hanging on a hoist ready to be dropped in. I have the manifolds off right now so it will be easier to get the top bolts on the transmission threaded in. so I'll finish uploading the pics when I'm done dropping it in.enjoy!
s**t looks good as hell
Modified by silvia s14.5 rb25det at 12:12 AM 7/2/2009
Modified by silvia s14.5 rb25det at 8:37 PM 7/2/2009
