DJPyro »
https://forums.nicoclub.com/djpyro-u43417.html
Sat Sep 30, 2006 2:13 pm
As stated, car won't start at all. I turn the key, nothing happens. No clicking at the starter, nothing. All the accessories come on, lights, radio, windows work, etc, gauges all light up.
I've tried jumpstarting it twice now, to no avail as well.
Also, as mentioned in the title, it's a 1991 hatch, with a blacktop conversion. Swap was done prior to my getting the car.
Previous owner said all I should have had to do was bleed the clutch and it should have fired. Didn't happen that way. Any suggestions would be lovely.
There are some loose wires in the area of the starter, but the starter appears to be wired, I haven't been able to get the car up high enough to get under and check for sure though. If it's that, then problem solved, however, I would think jumpstarting it should have worked. I've never tried jumpstarting a turbo'd car though.
It's a standard, and running 10lbs boost.
Modified by DJPyro at 5:45 PM 9/30/2006
