http://www.raktron.com/fuel/rewire1.html look that over and you will get the idea. The factory power wire is going to be the trigger for the relay.91HardbodyRB20DET wrote:so run a wire directly to the battery then to the relay.how do you use the relay or wire it to trigger it?
