zm830101 »
https://forums.nicoclub.com/zm830101-u101829.html
Mon Jul 21, 2008 11:51 am
i am having a little trouble with my hardbody. it is a '91 KA 5 spd 2wd king cab with 189000 miles.
it normally runs great. the only problem being a high fluctuating idle that is intermittent. just recently though it started acting up. when i go to start it i have to be very certain that it catches fire on the first start attempt. if not it fouls the plugs. the only way to start it if i miss on the first try is to pull the plugs and clean the raw fuel off of them or push start it.
then after it is running it idles very low and bogs when you try to give it throttle. the bog is only momentary and after the revs pick up to over 2000 it runs relatively smooth.
i have pulled and cleaned the injectors 'cause i thought at first that they might be hanging open. wires, plugs, distributor cap, rotor are all new as of yesterday. fuel filter is new. i have a new pcv as well as vacuum lines and was going to replace them to see if it cured the high idle issue but that has become a moot point now that it is barely running.
i am suspicious of the EVAP system because the tank always has pressure in it that is released when you take off the gas cap but i don't know if that would cause the troubles i have been having.
anybody know if a hotter plug would help with the fouling issues? got a part #?
any suggestions would be much appreciated
