91 distributor on a 95 motor?
fiveNdime
Car: 1970 Datsun 510, 1973 240Z
I am swaping a KA into my datsun 510. I dont know too much about the KA yet but I am learning. I did a search and found the motor I bought came with a 91 ECU and harness, but the motor is a 95. Can you put a 91 distributor into a 95 motor. And what else am I overlooking as far as compatability? Thanks for the help it is greatly appreciated!
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Yes, a 91 distributor can be installed into a 95 block. All the KA24 DOHC blocks are the same.
Be sure to include the 91 MAF, throttle body, and O2 sensor.
180fan
Car: 89 fastback
Well the 95 has the coil integrated into the distributor iirc, whereas the 91 does not. There will be a difference in the wiring for this difference.
fiveNdime
Thanks for the help 180fan.
fiveNdime
greatfull for the help! I think the water temp. sensor is different as well but I dont know about the thing next too it. I need to buy a shop manual for the motor first thats a better Idea. thanks again rogoman
