gullymonster wrote:Hey all, new nissan owner here, been reading through these issues already. I got my 91 d21 5sp 2wd with 150k this morning and already looking to attack some issues.
No tail lights when headlights are on, no cluster lights regardless of dimmer switch, and pretty sure oil temp gauge isnt working, bottomed out for whole ride, while warm air blew through heater. (Do have 3 inside dome lights work)
Wondering where i should look first, and if these issues are inter related via fuses or circuit, where the switches are to check/ cleanable?
Thank you all! All insight is appreciated.
On the '93 that I had,, the fuse panel was to the left of the steering column. It's been a while,, but seem's like it had a little finger pull indentation, to take the small lid off, or lower to expose the fuse's. Useing a flashlight you may be able to see right off which one is/not blown.
As I recall,, I did have a fuse to blow,, when working with hooking up the trailer light's one time. So check the pigtail for the trailer light's,, if it is installed. Could be just hanging down,, and one of the wire'z may have shorted. Just a guess though.
Could be the bulb's,, but easier to check the fuse's first.
A service manual is a wise investment. There may be a downloadable Nissan Manual here or at some other site. Nissan does have a Nissanhelp.com site to help as well. Haynes' or Chilton would be an aftermarket one. I had the Nissan & Chilton for the '93 that I had. For my '13,, so far,, I've just use the Nissan downloadable SM,, that I got somewhere,, maybe here, just don't remember.
Good Luck
