RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Thu Jul 30, 2009 2:10 pm
Compression test is one thing, to test rings versus valves find a shop that does leak down test. They compress the cylinder and see how fast it leaks down. Then they squirt oil in the cylinder and if it leaks down slower it is rings, if it is valves, it leaks down just as fast. The oil in the plug hole will slow leak down if it is rings as it seals it. If it is valves the leak down time is the same.
