ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Sun Jul 22, 2007 12:00 pm
If the under plenum hoses and knock sensors haven't been done recently (prob not if it's sat for that long) then they'll need replaced. You'll kill two birds with one stone by doing those along with the injectors. Do all 8 injectors and NEVER ever ever use gas that has ethanol in it. That should fix you up in that area. Do the timing chain guides and it should work well for a long time if the rest of the car does too. However, if the active suspension is in average condition (which is not good at this age) and you don't have the $$$ to do the guides, injectors, knock sensors, hoses, and whatever else needs replaced, I would like to buy another parts car.
