elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Dec 05, 2006 4:50 am
Bruce
Im reasonably sure that the 94/95 actives had the same steering ratio... You're right, the 90-93 had a quicker steering gear, however the 94-95 touring retained that quicker gear, and i THOUGHT the actives did too..!!!!
Remeber that handling is 85% tires and 15% suspension... So if you didnt have the same tires on the cars, then all bets are off.. Also, if the suspension wasnt OEM NEW on both, then all bets are off.. Too many variables when we talk about older cars.... In theory, the active hardware didnt change, so theres no reason why the 95 wouldnt handle as well... They may have used softer bushings, im not sure, but if your bushings are more than a couple years old, it doesnt matter what they were like to start out with!!!
Most exhausts wont add 30HP unless you join it with other mods... However, the general rule is that it takes 10-15HP to be BARELY noticeable... the 30HP the NICO ECU gains is noticeable, but its not a huge difference.... 10% isnt worth writing home to mom about....
the bottom line is, ive driven a known perfect 91 Q and a known perfect 94, both equally stock, and they arent htat much different... Maybe a little, but not a TON... Note that the ECUs in the 90-93 are more advanced (more HP), so by doing the ECU upgrade you may gain less HP on a 90-93 vs 94-95.. bottom line is, with the ECU upgrade, 90-95 Q become very VERY close....
FWIW im not trying to persuade you one way or another. There is something really goofy about those stupid 91/92 Q (93s are basically a 94 with a belt buckle)... Something that makes them feel special and unique... im not sure what it is, but they even feel different from my 94. WIth that said, i would trade my Q for a nice 91 or 92 active Q!
