'91-'93 240 with Tein springs. . . .
Wykid 240
Does anyone have any pics of an '91-'93 240 with Tein springs on. I'm trying to see how much the springs drop the car. Also, what are your impressions. . . . .I'm thinking about getting them and pairing them up with AGX 4-way adjustables. Thanks
-Jeramy
214kka-et240sx
Car: nissan s13 silvia
if you are planning to drift dont get tein springs they blow shock but if you are not then the are ok but the are not to stiff i would go with eibach springs ther are stiffer and they lower the car by like 2.2''
tr0ublemaker909
heres my 90 fastback with the tein springs, it is an alright drop compared to stock but its not a big difference, like kike said i'd go wit the eibachs if i could do it again, supposedly theyre stiffer and provide a better drop hehe but there u go
Wykid 240
214kka-et240sx wrote:if you are planning to drift dont get tein springs they blow shock but if you are not then the are ok but the are not to stiff i would go with eibach springs ther are stiffer and they lower the car by like 2.2''
I will be drifting the car, so what do you recommend?
-Jeramy
214kka-et240sx
any coilovers would be fine but if you have the money Kei Office but if the dont have that much MEGAN RACING is a really good set up
Juujai
how much $ to fiddle with?cheap kyb agx +eibach try to avoid the spring that lowers too much i forgot the name.more expensive koni yellow +eibach or ground control coils.then entry coilovers 1k-1.5k?and theres like a billion choices if you have a 2k-2.5k spending limit.
240DRFT
the eibachs suck. they are softer than the teins and they blow shocks since they lower so much. i'd go with the teins
twofortyesecks
Car: 08 Nismo 350Z
08 Ruckus
i have teins and if they were any lower I'd be dragging the bottom of my car. I'll throw up a picture tomorrow. They are good but I really wish I never lowered my car. I'm too poor / lazy to get the proper camber correcting parts. I go through tires quick.
Project S13
Car: Nissan 240SX Fastback
I have teins on my s13 but the car is not more than an inch lower than stock. I raised it after coming close to scraping on things here and there...haven't felt like lowering it. As for drifting I have the type HE's and have had no trouble with them breaking, though rumors abound about everything and somebody somwhere has surely broken teins drifting.
I think my teins are fine but I have heard great things about silk road and I may have tried them out if I could go back and do it again. The teins haven't dissapointed me yet though.
I have the Tein S-Techs as well.
As far as springs blowing shocks, sounds like you guys must have sucky shocks.
The vert is heavier than any of your coupes or hatches, and my cheap KYB's are fine with the Tein's. Nice ride, good drop.
kamikazestorm420
the eibachs are not stiffer than teins ..
214kka-et240sx
yes they are i guess you guys dont really drift that much and i dont have sucky shock i had KYB agx and tien they suck , eibachs are way stiffer and better my friend has those and he goes drifting at the track and it hasnt blown
biggie
I would compare the Tein S-Techs and the Eibach Pro-kits to be about the same. I've had both. Had the sportlines as well they suck, cause they have too soft of spring rate for being that low.
Pics:Here's my old one on eibach Pro-kits and GR-2s.
Here's my car with tein S-techs and stock shocks, when I first got this one.
Here is my car now for reference with D2 Coilovers 9/7 spring rate, no problems at all so far.
nismofly
Car: 89 Nissan 240SX Hatch
214kka-et240sx wrote:yes they are i guess you guys dont really drift that much and i dont have sucky shock i had KYB agx and tien they suck , eibachs are way stiffer and better my friend has those and he goes drifting at the track and it hasnt blown
EIBACH PROKITSpring Rate - F : 1.84~1.92kg/mmSpring Rate - R : 2.3~2.4kg/mmRide Height - F : -1.8" (eibach site) -1" (jnm240 test)Ride Height - R : -1.6" (eibach site) -.75" (test)
EIBACH SPORTLINESpring Rate - F : 1.92~2.0kg/mmSpring Rate - R : 2.4~2.5kg/mmRide Height - F : -2.2" / -1.75" (test)Ride Height - R : -2.1" / -1.75" (test)
TEIN S-TECH(progressive, TEIN only lists the maximal rate)Spring Rate - F : 3.7Spring Rate - R : 3.2Ride Height - F : -1.5"Ride Height - R : -1.2"
TEIN HIGH-TECHSpring Rate - F: 3.3 (s13); 3.2 (s14)Spring Rate - R: 2.9 (s13); 3.1 (s14)Ride Height - F: -0.9" (s13); -0.7" (s14)Ride Height - R: -0.6" (s13); -0.4" (s14)
the teins are progressive yes, so they might feel softer unless you really push them, but eibachs are only the first step up from stock
if you really want to push it and can afford it, get RS*R race or something similar with AGX or even better koni yellows
214kka-et240sx
well i guess i wont argue bout it
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
AZhitman wrote:Nice ride, good drop.
I just installed my S Techs and I would have to agree with this assessment. I will be pushing them in June on the auto-x, so that will be a better test than tooling around the 'hood.
Wykid 240
I want ot get coilovers but don't have the money for them, that's why I'm going with a spring shock combo. . . what coilovers are there for a good price?
-Jeramy
Megans from Underground.
Best bang for the buck, tell 'em you're from NICO.
corn322
Car: 1993 240sx
TEIN Basic coilovers are cheap, I've seen them for like $800-$900.
Wykid 240
AZhitman wrote:Megans from Underground.
Do they have a web site or number?
-Jeramy
nismofly
WeldingHank
Car: 1989 240sx CA18DET
Before
After
