robomatic12 »
https://forums.nicoclub.com/robomatic12-u138186.html
Sun Jun 13, 2010 3:30 pm
NOW SOMETIMES I SMELL ALOT OF GAS. LIKE IF ITS RUNNING RICH BUT NOT ALWAYS.
SOMETIMES I SMELL OIL BUT ALSO NOT ALWAYS.
-Do you smell gas in the engine bay or in the cabin? Or are you smelling a rich gas out of the exhaust?
I REPLACE SPARK PLUGS OLD ONE WERENT AS BAD NO SIGNS OF OIL OR FOULING...
REPLACED THE TWO SENSORS WATER TEMP AND ENGINE TEMP. PUT NEW OIL NEW FILTER..
What did you replace the spark plugs with? Did you use the OEM plugs? Anything else will cause hesitation. Did you use
oem sensors?
IT FEELS LIKE ITS THE LEFT SIDE CYLINDER. THEY DONT MAKE AS MUCH NOISE AS THE ONE ON THE RIGHT PASSENGER SIDE..THERES ALOT OF DRY OIL AROUND THE BOSE TO THE PCV VALVE. I CANT FINE ANY VACUUM LEAKS. SUMTIMES I HEAR A HISSSS...... PLEASE HELP ME.. ITS DOING REAL BAD IN MILEGE TO IM GETTING LIKE 60 ON FULL TANKS......
What don't make as much noise? The injectors? A hiss is a vacuum leak btw.
SO ALL IVED DONE TO IT WAS CLEANED THE CONNECTORS TO TPS,
MAS AIR SENSOR, CLEANED THE SENSOR UNIT MAS CLEANER,REPLACE THE TWO TEMP SENSORS,NEW PLUGS, CLEANED THE COIL TIPS TO SPARKPLUG. HAS COLD AIR INTAKE.I TRY ADJUSTING THE TPS IT IDLES EITHER LOW OR HIGH BUT CANT GET IT TO IDLE BACK TO 800 RPM OR NORMAL....
You need to clean all of the injector connectors and the coil pack connectors, normally everything has green corrosion and causes rough running. Sometimes the connectors are broken and you need to replace them. You need to remove your TPS and clean it or replace it. There is also an easier way to clean it by removing a part of the TPS hose and spraying WD-40 in it with the engine running. Google "300zx tps cleaning".
You need to pull codes from the ECU first. If you do not know how to do this, google "300zx ecu codes". You need to learn to search for this stuff. Then you need to pull each coil pack connector and see if the RPM drops. If it does not drop on one cylinder, that cylinder is not firing and we can figure it out from there. I believe you are looking for 10-13 ohms for the injectors.
