This is what I am assuming:
I think this piece broke at the rubber part
https://conceptzperformance.com/Cart/de ... hp?II=1877
and he wants to weld this "A" shaped bracket into a sold piece so he can eliminate the above support
https://conceptzperformance.com/Cart/de ... php?II=609
Anyways, Ive welded the the stock bracket, but you need to "beef" it up. The stock stamped steel is pretty weak and will more than likely bend on you as it was made to have two support points(at the transmission and the rubber mount as shown in the first link.
The other option is to weld a "u" shaped flat bar to replace the rubber piece that broke on the plate.
