Thanks for the reply! I was expecting a notification email when someone replied but I guess not. Oops, my bad
The 02 sensor test passed and now I have some new problems. I am getting code 32 and 34. Knock sensor and EGR system. I heard that EGR problems can be simply from clogged lines but I don't know how I'd go about cleaning them. I took a look into the engine bay and I tried to spray carb cleaner around some of the vacuum lines that I saw. The hardest part about this was finding the lines! I only found 2 or 3 lines to spray and those ones I did, didn't raise the engines idle at all.
The engine is starting to get worse it seems. I have had numerous stalls when coasting to a stop and starting from first is incredibly hard from having so little power.
I did a seafoam treatment to the engine and I felt a huge power increase on the top end but it did little to the low end hesitation.
I looked and the plugs in the car were the BKRGES and not the recommended PFR6B-11 plugs. I have 6 new PFR6B-11 plugs on the way to see if that helps anything.
I'm thinking of getting a Nissan technician to look over the car and see what he/she says If i don't make progress soon.
Any help would be greatly appreciated.
