elks 240 »
https://forums.nicoclub.com/elks-240-u6569.html
Mon Nov 29, 2004 6:16 pm
this is a 91 240sx manual about 150k on it, it sat for a long while maybe 8-10 months in oklahoma. only code it is throwing is knock sensor.
it will start up if you give it half throttle steady, it idles between 500-800rpm, (no matter how much you mash the gas ) and if you pull your foot off the gas it dies. the ignition timing, the pin sits about an 1" to the left of the timing marks on the pulley.it appears to be getting fuel as it is drenching the plugs.
i changed the fuel pressure regulator, tps sensor, plugs, wires, coil, ecu, and still nothin. all were known to be good. will be checking the distributer to tdc tomorrow to see where it is.
you can hear it trying to suck in air cause it makes a different noide when you give it full throttle.
i am out of ideas, any help would be appreciated.
thanks, john
