destroyyourmind wrote:so my 91 is having some electrical problems I just swapped the ka24de in I just got and wired it up but before my transmission and motor gave out on me the last time I had no problems headlights retracted gauges came on. and after the swap nothing works but the backlight to the clock with no time though and the headlights come on but wont retract. the first time I tried to start it , it turned over for 2 seconds then died and it wont turn over at all . and none of my fuses are blown any one have any ideas? there was one plug on the top of the transmission that was broken and another behind my motor plugged up to vaccumn lines . I replaced all the lines when I got the motor too.
1. All vacuum lines and wiring must be connected OK---> 2.Check battery if its dead (turn lights inside car, check headlights etc) NO GOOD (re charge battery and check connections) OK ---->3.Turn the key on (no thing happens and all you hear is click) NO GOOD (check starter and connections) OK-----> 4. Motor cranking but not starting (check fuel, spark, timing, and compression)
p.s: if none of this works, try powering your starter directly and the motor should turn over unless it is seized. theres a good chance that your grounding out somewhere and all the power from your battery is going no where.
