hmart95367 »
https://forums.nicoclub.com/hmart95367-u83745.html
Tue Feb 12, 2008 8:41 pm
I checked for spark that's ok, My problem is electrical this has happen before and some how it fixed itself. It cranks fine but there's no fuel presurre. I have replaced... fuel pump, sending unit, fuel pump relay and fuse (s). Here is the problem. I get 12v at the electrical connector, I don't hear the pumping like usual. I pull it out of the tank, lay it on the it's side and I'm still not getting any power to the pump. I turn the key on the pump works for about 5 seconds and it stops. I have power to the sending unit, when I pull the pump apart from the unit and connect 12v directly to the pump it works great. Put it back together and inside the tank and no juice to the pump. Somehow during crank it looses 12v to the pump??? Someone help, my kid is driving my 8 cylinder 4x4 using alot of gas!!
