91 240sx to a 180sx?
prman89
Car: fixing and improving things
i have a 1991 nissan 240sx stock..(i just got it so it wont stay stock for long) i dont want to turn it into another s13 conversion but i do wan to change it to as close as i can get it to a jdm 180sx dose any one know any sites or places i can go to, so i can get the 180sx emblems and all the other stuff that come with it. i have the same overall body style as the 180sx but i want to get the emblems and interir asseries that go with the 180sx i mainly want to try to get the look of a 180sx. thanks for any hints and tips (for all the 240/silvias out there i mean no disrespect to the style yall choose i just like to be diffrent.)
solaris22
uhh the only thing that's different (besides RHD) is the rear garnish and the floor mats and tach...I think that's it
NeedCAforS13
Car: CA swapped S13 coupe
you could get all the late model 180sx body stuff I suppose... the kouki aero bumper and side skirts, and the 180sx wheels as well.
the actual factory aero parts are really hard to find, but there are afew companies that make knock off's of them... the wheels are standard on the base 4 lug s14's (same as 180sx wheels):)
http://www.importfan.com/produ...=4651
there's one that will be available state side here soon, and it looks to be relatively well priced. not sure of the quailty though.
read all about it here: http://jspec.com/18koukcon.html
Sean
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
Where can I get a 180sx rear quarter windows??
NeedCAforS13
ebay... http://cgi.ebay.com/ebaymotors...42611
or maybe if you know someone in japan:)...
Sean
solaris22
I'll be parting my car out in 3 months...
phase2 also sells the type-x bumper
http://www.store.yahoo.com/pha....html
BomexS13
'00 Toyota Celica
NeedCAforS13 wrote:ebay... http://cgi.ebay.com/ebaymotors...42611
Sean
SUcks...somebody got it already:mad:
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
man i love that kouki bumper
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
SmithSR
Car: 240sx
What's the REAL difference here? Where the driver sits.
180 or 240?
P.S. thanks for the pics, Mike
quiksilvia
Car: 95 s14 se
those rear quarter windows need to be cut out a special way, be aware of that
solaris22
if you have a razorknife your all set, just a thin layer of window adhesive on there...plus a 1 bolt at the base of the window. Broke one of mine in a fuel-pump-install-rage...
180fan
Car: 89 fastback
Center garnish and windows are the obvious ones. The not so obvious differences are the front signal lights and side markers. The front signal lights are two tone amber and clear, while the side markers have a bulge on them instead of being flat. The later kouki models had a body kit (front bumper, spoiler, skirts) in addition to losing the two tone and getting smaller seperate turn signal lights and daytime running lights.
As for the window, when you take them out, you'll need a window sealant cutter. It looks like a reciprocating saw or you'll need a wire saw. Be careful with the weather stripping around the window though as most of the JDM ones are thrashed when shipped here. You'll also need 3 of those little plastic bolt like things which are used for lining up the window properly and the long flat rectangular section which presses up on the body.
BomexS13
'00 Toyota Celica
180fan wrote:Center garnish and windows are the obvious ones. The not so obvious differences are the front signal lights and side markers. The front signal lights are two tone amber and clear, while the side markers have a bulge on them instead of being flat. The later kouki models had a body kit (front bumper, spoiler, skirts) in addition to losing the two tone and getting smaller seperate turn signal lights and daytime running lights.
You mentioned the side markers. I think most JDM sidemarkers, in any car, have that "bulge" on them. I have some JDM sidemarkers on my celica, its has that "bulge".
As for the window, so it needs some cutting? And can we just get some weather strip from the dealership, or it has to be from japan?
POS_S13
Car: thizzlamics
BomexS13 wrote:You mentioned the side markers. I think most JDM sidemarkers, in any car, have that "bulge" on them. I have some JDM sidemarkers on my celica, its has that "bulge".
solaris22
180fan wrote:As for the window, when you take them out, you'll need a window sealant cutter. It looks like a reciprocating saw or you'll need a wire saw. Be careful with the weather stripping around the window though as most of the JDM ones are thrashed when shipped here. You'll also need 3 of those little plastic bolt like things which are used for lining up the window properly and the long flat rectangular section which presses up on the body.
or a razor knife like I said...and you don't need those plastic things, I took mine off when the window broke and the window fits perfect
180fan
Car: 89 fastback
Yeah I suppose the razor will work too. Just it'd take too long, but then again it'd probably save the weather stripping if you're careful. The weather stripping that goes around the window is NOT available through the dealership. You must buy the stock 240sx windows to get the weatherstripping and even then they're bonded to the glass so you'd have to peel it off very carefully not to stretch the stripping. Reason I know is because I've got the windows in my garage waiting to be installed but I just don't have the time or money to invest into a project like the 180sx window install now, the SR buildup and replacing of my stolen muffler comes first.
BomexS13
'00 Toyota Celica
POS_S13 wrote:
does anybody know of a shop that has this in stock? My stock ones are busted, might as well get this.
BomexS13
'00 Toyota Celica
180fan wrote:Yeah I suppose the razor will work too. Just it'd take too long, but then again it'd probably save the weather stripping if you're careful. The weather stripping that goes around the window is NOT available through the dealership. You must buy the stock 240sx windows to get the weatherstripping and even then they're bonded to the glass so you'd have to peel it off very carefully not to stretch the stripping. Reason I know is because I've got the windows in my garage waiting to be installed but I just don't have the time or money to invest into a project like the 180sx window install now, the SR buildup and replacing of my stolen muffler comes first.
My stripping on my stock windows are so tore up. meaning ALOT of scratches, so is there any other way to "restore" it or just get new windows with better stripping/molding/or whateve you call it.
180fan
Car: 89 fastback
BomexS13, you can find those corner lights from ebay for about 65 + s&h. Pretty steep if you ask me. As for the weather stripping that goes around the edge of the windows, no there's nothing that can be done unless you purchase new windows which are expensive.
BomexS13
'00 Toyota Celica
180fan wrote:BomexS13, you can find those corner lights from ebay for about 65 + s&h. Pretty steep if you ask me. As for the weather stripping that goes around the edge of the windows, no there's nothing that can be done unless you purchase new windows which are expensive.
THat sux that i have to get new windows to have new strips. Might as well order a brand new 180sx window. As for the the jdm markers, price isn't that bad.
180fan
Car: 89 fastback
What you can try to do is go to the junkyard. If they're in decent shape, tug at the little corner section, there should be a tab. But peel upwards very carefully and remove the section where the rear and passenger/driver windows meet and continue to peel from there. Take a razor blade and cut along the bottom between the quarter panel and the glass to get the bottom section removed. Give that a shot.
