Equinox »
https://forums.nicoclub.com/equinox-u8506.html
Fri Jan 14, 2005 9:20 pm
I am getting an intermittent problem when I start the car. Every now and then when I start the car, it will stumble at idle for about 30 seconds or so. Then the car levels out and after that it runs perfectly. It doesn't happen all the time and I can't figure out exactly what is causing it. Other times the car will fire up, start, and idle perfectly.
I've done all the routine maintenance: new plugs, wires, rotor, cap, and fuel filter. Compression checks out 180psi across the board. And no check engine light. Any ideas??? Thanks.
Modified by Equinox at 9:33 AM 1/15/2005
