91 240SX STAYS RUNNING WITH NO KEY
GTBAKER
Car: 280 ZX
CAR STAYS RUNNING WHEN YOU REMOVE KEY. CAN STALL ENGINE AND DISCONNECT BATTERY. HAS ANYBODY SEEN THIS BEFORE?
vancouverbc
Car: 1991 240sx
i think ignition switches go bad sometimes. jiggle it to see what happens.
zerothread?id=85879
vancouverbc
Car: 1991 240sx
GTBAKER
Car: 280 ZX
DID THAT SEVERAL TIMES STILL SAME THING
vancouverbc
Car: 1991 240sx
the ignition switch is on the other side from the key. its quite small. you can test with multimeter. $47 at napa. its a very simple switch. the key just rotates it. if you stick a screwdriver in the blue part you can rotate it like the key rotates it and test.
Modified by vancouverbc at 7:16 PM 1/23/2008
GTBAKER
Car: 280 ZX
DISCONNECTED IGN SWITCH STILL RUNS???
vancouverbc
Car: 1991 240sx
You disconnected the electrical connector as circled in this picture? Ok, its not the the switch then.
vancouverbc
Car: 1991 240sx
http://img167.imageshack.us/my...8.jpg
click the above pic to get medium or large picture. if you see the number 3 terminal on the starter switch, it goes to ignition coil and also back to the relay box to give power to fuel pump. if any hot wire is touching this wire, your car will continue running. a wire for example could be loose under the relay box by battery.
do a search because it might be a common cause for this.
