Well, I got the AFC back to factory settings and redid it from the beginning. It should not be a variable anymore. Topped off the radiator and overflow resevoir so it should be good now.
The 02 sensor has a warranty so I'm switching it out here in bit.
Still idles high, doesn't drop down now, just sits at 2k or around there. Thought it might have been the air regulator not shutting. But that hose is too tough to squeeze so I just unplugged it, nothing changed. I can make it idle down if I squeeze the main idle control line enough, I can even kill it. That would make me think it would have the idle set too high... if it weren't for one thing. If you race it and let it idle down it gets down to like 1400 (maybe less, can't remember) or so and something changes. It sounds like it is running really rough on all cylinders. Not stumbling or anything, just "brrrrrr". Then no more than a second later it switches back (smooth again) and idles up to 2000.
That one kind of has me confused. I'm going to dig the timing gun out again, maybe p00t was right. It seems like the computer is messing with something and then switching back, no engine light, but I'll see if self diagnosis finds anything.
Other than that the car runs fine, drives nicely, runs smooth, has plenty of power. Just the idling and the strange momentary roughness to figure out.
BTW I appreciate all the help, I know this must seem like a bother sometimes, but you have my thanks
