91' 240sx starting problems
240_all_day
Car: 1991 Nissan 240sx
well i just rebuilt the whole engine. It has compreshion and the timing is right. But it still won't start, does anyone have any advice?
theother1wstolen
Car: 92 240sx Coupe SE
never ever post just saying "my car wont start, why?" be more specific, is it just clicking and not cranking, is it cranking but not turning over, is it doing nothing. what is it doing.
Ladreik
Car: 92 240sx se Coupe
Yeah... need more info... Does the starter turn over? do you hear nothing? do you hear the magnetic switch energize? Do you have fuel... spark?
240_all_day
well it turns over, but its not cranking
Ladreik
Okay, The starter is not cranking at all. Check the fusible link first, take it out ohm it out sometimes it is not too obvious if a fuse or fusable link is blown. The fusable link is in the fuse and fuseable link box next to the battery, im pretty sure its a green fusable link and is 10 amp.... also verify 12vdc is at that point. Verify you have 12vdc at the magnetic switch on the starter (the solenoid)
Do you have a manual or A/t?
240_all_day
yeah there is spark and fuel
240_all_day
i have an auto
Ladreik
Alright check that stuff first and if all of it is good it can be a few other things including your inhibitor switch and your solenoid (magnetic switch)
