Postby
xckid »
https://forums.nicoclub.com/xckid-u23378.htmlWed Jan 18, 2006 8:45 pm
as it says . By the way thank you nistech and everyone for helping me getting my car moving.. Yeah i tried adj the screw for idle but seems as its allthe way back.it idles at 1000~900 i would like to have it at normal.
Postby
xckid »
https://forums.nicoclub.com/xckid-u23378.htmlMon Jan 23, 2006 5:46 pm
WELL JUST FILLED IT UP TWO DAYS AGO AND NOW AFTER SCHOOL ITS EMPTY. BUT I THINK I FOUND THE PROBLEM THE MASTER CYCLINDER . AS I WAS LOOKING AT IT I NOTICED A BUNCH OF FLIUD AROUND IT WHERE YOU BOLT IT TO THE BRAKE BOOSTER SO I TOOK IT OFF AND NOTCIED AS IT HUNG THERE THERE WAS BRAKE FLUID LEAKING OUT OF THE MASTER CYCLINDER SO I FIQURED IT WAS THE MASTER CYCLYINDER . I PUT IT BACK ON AND TIGHTEN IT UP SOME MORE DRIVE IT AROUND FOR A WHILE " NOT VERY SMART OF ME" GO BACK HOME AND IT STILL HAD THE BRAKE FLUID IN THERE AND WASNT LEAKING. SO MAYBE IT WASNT TIGHT ENOUGH . HOPEFULLY THAT IS WHERE THE IT WAS LEAKING FROM ALL THIS TIME..I ALSO HAVE ANOTHER CONCERN WHY IS MY RIGHT REAR CALIPER NOT FEEL LIKE ITS WORKING. WHEN I PULL IT UP ON MY DRIVE WAY WHICH IS POLISHED SO ITS SLIPPERY ONLY THE LEFT REAR WORK AS IN LOCKS ??? WHY -THANK YOU-
