91' 240sx RB25, when do i need too Tune it
havik420
Car: 91' 240sx RB25
Hey, I got a cold air intake and and exhaust, and will be putting on a ISIS intake mani and FMIC along with a Q45 throttle body and 255 fuel pump.. and im not sure how the tuning thing works will i need a different ECU or stand alone EMS, looking for some guidaince
Thanks
Rex
Car: None
Moved to RB sub-forum
legit240sx
Car: 91 240sx rb20
you should be fine with the stock ecu tuneStandalone is way beyond what your doing to this point.the fuel pump is fine with out the tunemani, throttle body, and fmic are fineexhaust and intake are fine
you should be good just swapin everything
Sil240
Car: Nissan S13 "The One Cam Wonder"
You'll NEED to tune when you put a bigger Turbo or bigger injectors on there.
You CAN tune when you do your mods, but it'd be a waste of time and money.
zer...25det
havik420
Car: 91' 240sx RB25
Yeah i want to go to 550 hp, next month i will be putting in n1 oil n1 water, cam gears and pully kit.. then 770 injectors and gt35r turbo.. then build for more security and maybe make it so i can take 10,000
thanks guys
BigJuiceSr20
Car: nissans, mazdas, soccer
Lemme know when you want to go standalone with PnP harness and base maps. I got something for you that's loaded with features and even has adaptive learning mode like a lot of OEM ecu's.
BTW...It's not Tec3
240SXcoupeRB25
Car: nissan 240sx
if want to get to 500 hp homie i would jus rebuild your rb25det.cuz i have rb25det into my s13 coupe homie and its running stock 4 now until i rebuild my rb...
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
wtf, can you spell correctly? i think homie needs is 650s, z32, the gt35r and a tune to make 450-500whp if tuned correctly
240SXcoupeRB25
Car: nissan 240sx
if he is jus using stock internals to drift and drag ect..and all he did is put in a bigger turbo in it then he gunna have problems with his motor homie..i know i have already tryd it with my rb25det
n8RPS13
Car: 90 S13 Fastback
Hey homie try speaking english homie....and not using homie every other word homie...
boosted98gst
240SXcoupeRB25 wrote:if he is jus using stock internals to drift and drag ect..and all he did is put in a bigger turbo in it then he gunna have problems with his motor homie..i know i have already tryd it with my rb25det
Not every motor is the same, each motor and tune are different. My buddy is running a complete stock long block except turbo, fuel cam's and springs basic stuff with a nice ems and has been over 500whp for a few years without any issues. It all comes down to how the car is set up and tuned, some people get lucky with their motors, others dont.
SullivanRacing06
turbo, injectors, maf, ecu n 255 are what you need to make serious hp, a i/m and other things are not needed.
if you tune it correctly youll have your 500 mark in no time, just be sure youve got a healthy motor homie
240SXcoupeRB25
Car: nissan 240sx
thatz what am trying to do with my rb25det to make handle 500hp like nothing.But first am rebuilding my whole motor with better cams gears rods and ect to make jus right
neonbomb
Dayum homies this thread is fat
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Leakdown and compression check... figure out your starting point... tune will be key for reliability and at those levels it's more common to see a stock motor blow up than last
Don't forget... said it before... these are used motors and there's no getting around that fact. Understand your motor's current cond and procede from there... good luck and welcome to the world of RB's!
havik420
Car: 91' 240sx RB25
550 is where i am going to take break, Then i am doing s13.5 conversion and making sure everything on the outside is to the best i can make it, then the inside, and back to the motor and see how much money and how much of my life i can dump into it, 3 years is my time range for now
