91' 240sx question
240sx350
I found a 91' 240sx in some classifieds and i havent had time to go and look at it. From the description the body is in pretty bad shape and it has a bad motor and transmission, which isnt a problem because i want to do an engine swap. are there any problems with this year or anything that I should look for when i go and look at it. Thanks.
namwons_240
Car: 97' 200sx ser
*sigh*...the problems with buying used old 240's
Common:bushings are probably shotmaster and/or slave cylinder shotcracked dashripped driver and/or passenger seats3rd gearworn slipping clutchdented front fendersfaded front and rear bumpersbad or missing side blinkers
Might have missed some but those above are pretty common.
240sx350
Thanks, most of those wont matter because I am going to put a new engine and transmission in it. I am more worryed about the frame and the suspension
Alfador
Car: 1990 Nissan 240SX Hatch
so you're basically buying the frame? yeah things should be mostly okay. Make sure you're only paying for the frame. And if you want you can pay a local mechanic around there to look at it and give you a report.
cdlong
Car: '95 240sx
how much? i've seen car in the junkyard that sound better than the one you described.
check the frame rails where they turn to go up into the engine bay, that's a common place for rust. a car with crumbling frame rails isn't suitable for a swap.
young-gunn
I didn't figure the dents were common I thought it was just my car, and the side blinkers, I have one missing too, why does this happen commonly, and lastly can someone explain more in depth about the 3rd gear thing, I know it has a grinding sometimes which was made up for by the wieghted shift knob, but why exactly does this problem exist? thanks
Oh, and sorry I sort of hijacked your thread..
