navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Mon Aug 24, 2009 3:19 am
i would confirm myself by flushing the system, filling it back up making sure to open the block bleed plug and make absolutely sure that it is full, then see if its still loosing coolant. if it is, then you can start trying to confirm that it is an internal leak.
Go ahead and check your oil too, make sure you dont have water mixing with it. just pull out the dipstick, if there is water in it the oil will be a milky tan color.
