HachiRoku »
https://forums.nicoclub.com/hachiroku-u1165.html
Mon Oct 09, 2006 9:24 pm
I was replacing my pads and rotors last week and while I was removing the caliper pins for cleaning and greasing, the upper pin on the front calipers mounts were stuck. I was able to spin the pins, but I could not pull or push them in or out of the socket.
I asked a friend about them and he says some cars have brakes where the pin is designed to stay in place but is free to spin for quick brake pad jobs, but I find it hard to believe the S13 would have that kind of design because the calipers would squeeze the pads down when I bolted the calipers back onto the housing.
Assuming this is not normal, is there anyway I can remove the stuck pins so that I can clean and grease them? I bought new boots for the pins but didn't install them because I couldn't access the pins.
Modified by HachiRoku at 12:48 AM 10/10/2006
