Hi I have a KA24DE engine that was swapped over from a wreck and pieced together. The EGR is completely gone and the hoses are plugged according to a write up here on the forum. (aside from big one under the throttle, I think I need it for idle)
The engine runs strong, I can press on the gas and make hard acceleration and it won't miss a beat. (Used to before the vaccume was capped)I have new Platinum4+ plugs, new O2 sensor and plug wires along with new distributor and timing adjusted by an experienced mechanic.
But the car is running a little rich and builds up carbon on the spark-plug over time which causes the plugs to not fire well. I've already replaced the plugs but I suspect the fuel is still rich.
Is there a way I can adjust that? I was thinking of messing with ECU but it seems to cost a lot. Is it a good idea if I let some air bypass the MAF to remedy it? I think the MAF is OK since I can accelerate and idle very well, just that rich fuel is still there to a degree.
Thanks
